Sheet Metal - prepare separate functions for edge preparation
In Creo parametric, edge preparation is located "inside" the Flange or Flat-KE.
This results in Problems for edge- and corner-preparations that depend on both Flanges.... and most of them I do are depending on both flanges!
For excample, you will not be able to build a closed edge (like Picture) using two separate Flange-KE with adequate work
You will have to reduce the base by (bend radius + thickness), add two flange-KE and then extend each of them to meet at the corner. Repeat this if you have multi-bend-flange-KE.
So, now... Whatif I change the sheets thickness?
you will have to overwork each single KE
sorry for mentioning an other CAD-System, but using HiCAD it is more comfortable, there are separate functions for creating edges like this (independent how the flange was created before)
My Idea:
provide separate functions for "edge preparation" (e.g. closed edge with/without gap or overlapping) and trimming flanges together (e.g. mitre with/without gap)
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
