Currently, in Creo 2 drawing mode, when we show a flat pattern of a sheet metal part, we can get the parametric bend angles to display. But, it seems to be 'hard coded' to 2 decimal places. it would be nice to be able to set / alter that, as we do with dims.
2nd: It also would be nice to be able to move the anchor point for said bend angle note. Currently, it is attached on the mid-pint of the bend line. To slide it along the bend line would be a nice touch.
We can alter the number of decimal places, and also the anchor point, but we then loose the parametric relation.
