This is more of an enhancement that an idea.
To be able to make a swept flange shape along a chained edge, when the planar shape is irregular, and has an angle or two greater than 145° .
Currently, you can't sweep a flange along an edge with an irregular / non symmetrical shape. You can, however, get the flange when you shell the part from a solid, but not with a swept flange.
