In sheetmetal a user can create a bend order sequence. This means setting up a bend order sequence in the sheet metal part that can later be accessed by the drawing and displayed with Show Model Annotations to display a bend order table.
In that report there is a line item referring to the number of bends.
It would be very useful to have a sheet metal parameter that has the total number of bends in a sheet metal part, that can be referenced without the need to create a bend order table and manually inspect the table to report the total number of bends.
Could a sheet metal parameter be added that updates automatically and lists the number of bends in a part as an integer eg. SMT_PART_BEND_QTY
