In Sheetmetal unbending creates bend notes.
Currently it is possible to modify:
- symbol for type and direction of bend note.
- add inner or outer radius
- angle
It is not possible to define which angle is shown in Bend Note - supplementary or complementary.
It is quite simple in some other softwares.
Suggestion for PTC:
- Current config: smt_bend_notes_order &type&direction&angle
- Modified config: smt_bend_notes_order &type&direction&angle (&type&direction&comp_angle)
