Sheetmetal Forms - Dependant Merger vs Independent Inheritance
0 Kudos
Creo 4 default is "Copy form model using dependent merge". This setting only allows you to select Automatic Update in the shape tab.
Would like to have a config option to set "Copy form model using independent inheritance" as a default, this allows user to choose insert type. Could possibly combine these buttons as an alternative and to set Shape tab to Automatic as default.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
