If you create a sheetmetal in Creo Parametric that has a corner of a V shape, like this one below :
If we add chamfers to the edges, the flat preview shows incorrect dimensions :
The problem is that the feature FLAT PREVIEW relies on these 2 parameters :
- SMT_FLAT_PATTERN_LENGTH
- SMT_FLAT_PATTERN_WIDTH
These 2 parameters calculate dimensions related to the pilote surface. Can you upgrade the feature so it gives a correct calculation also for chamfered sheetmetals?
Thanks in advance
