There should be an functioanlity to Super Impose the Graph Results of an Analysis in Creo Simulate.
We're analysing an Thicken Plate, So the results on the Top Surface is different from Bottom Surface.
So to compare the Results of Top Surface with Bottom Surface, we want to Super Impose the Results.
So that it'll be easy to compare the results.
Right now we've to export bo the results as an EXCEL sheet and need to Super Impose over there.
But if the Analysis results get modified, we've to do the same process again and again.
Niranjan V
