Show ALL the constraints in Creo 3.0 placement tab (assembly)
In Creo Parametric 3.0 when assembling components, "Constraint Type" list shows only 4 choices and needs to be scrolled. This did not happen in Creo Parametric 2.0.
PTC R&D says: This works to spec. We made this change due to other customer complaints the constraints list was too long, especially since they did not need to see the entire list.
Please reorder the information in placement tab to show ALL the constraints:
2 Comments
dgschaefer
Yes, please!
I'd also vote for expanding the fields showing the placement references.  They are too short and the only way to see the full reference info is to hover over it and read the tool tip.
PTCModerator
Emeritus
