Show config.pro file uploading directory path in Configuration Editor window in Creo
Just like Pro/ENGINEER Wildfire 5.0 or before version. can show config.pro file uploading directory path when clicking TOOLS> OPTIONS.
From Creo 1.0-2.0 unable to  Show config.pro file uploading directory path in Configuration Editor window.
7 Comments
gzhou-2
2-Guest
This is very important functionality for engineer to analysis issue caused by config.pro options. Now have to check it by File > Help > System information.
ptc-4239699
1-Newbie
Why more and more useful functionalities are regressive or missing??
yliu-6
2-Guest
Missing from creo 1-2, this will be as an enhancement in Creo x.0
ptc-4658901
1-Newbie
YONG FEi LIU is just right. Some perfect functionalities are available in 2001 release, but are missing from Wildfire 2.0, then adding into Wildfire 3.0 or 4.0 as new enhancements.
yshen
1-Newbie
Good news from Technical Support. Referring to https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS70890, this functionality is enhanced in Creo 1.0 M050 and 2.0 M030.
lbai
It works well in Creo 1.0 M050, but 2.0 M030 is not available until now
PTCModerator
Emeritus
