When using ruled layers, datums, axis, points, etc. are added to layers as they are made and disappear from view. This can be frustrating when working in a large model where unhiding a layer can show too many items making it difficult to select the one needed.
An option to show an item, temporarily overriding the layer state, would be very helpful. This could be an option to "Show" in the right click menu that would reset with "Unshow" and would be reset the next time the model is opened.
I know I can either remove the item from the layer or use "Exclude... in the layer properties dialog box. However, this takes more time and does not reset at the next open.
