Its very annoying to see HOLE in design tree instead 1/4-20 Tap or 6-32 Tap, or
dim (symbol) 1/4 Hole
This is an awesome idea. Should throw in OOTB configurations for US and other regions to make the UI, the callouts and the new model tree names more useful across the board.
Great Idea!
