Showing Model Annotations
In the graphic area the demotions overlap and it’s difficult to find and select the desired dimensions. In addition, the table doesn't help to select because it does not show the dimensions values. The column of dimension type is irrelevant. they appear in red color and the user must REPAINT to see them in yellow color as other exciting dimensions.
Requests:
  1. Automatically arranging the display of dimensions (Clean Dimensions)
  2. Add column for dimensions values in table.
  3. Add dynamically filter search for table.
