When creating large assemblies, it is convenient to group items within the model tree as the assembly becomes more complex. May I suggest allowing a user to select groups when creating simplified reps in order to include or exclude those groups with one click. Same idea applies to patterns (hardware patterns for example).
Currently, the user has to manually explode the group or pattern to select items within. This can be very cumbersome and time consuming. Thank you.
