Simplified rep Rules should be able to Override all Settings
Currently, simplified rep rules only apply when components are set to derived.
Please allow the use of rules that override all other settings.
For example:
If a component is set to Master Rep, and there is a rule applied that removes all components with a yes/no paramerter called Fastener set to yes, then the rule takes precedence over all other settings, master, derived, etc.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
