Simulate Graph Results - edges in templates
Currently you cant save graphs that use edges or curves into templates in Simulate. (CREO3)
This creates an enormous amount of down stream work or just a whole bunch of ugliness - measures on arrays of points
Additionally when you come to select curves, there is no intent manager
  - cant intelligently chain or loop curves, just select individual curves
  - deselecting curves is just as problematic
  - selection highlight is dumb - highlights unchainable curves which on the next click are rejected
In closing out the edge selection there are two dialog boxes to navigate
  - the first box allows default selection of OK with CMB
  - the second box doesn't have a default selection, it should have OK as default
There desperately needs to be improvement in this area - it is a major source of inefficiency for the user
1 Comment
olivierlp
Community Manager
Status changed to: Archived
