Sketch Regions also available in internal sketches
Sketch Regions are now only available fit external sketches and this wat of working is not available in internal sketches.
If available in internal sketches a lot of trimming  has not to be done anymore. This maken sketches more stable and working more productive. Also areas may overlap. In that case simple click the areas which have to be extruded without having to create closed loops which do not overlap.
1 Comment
mwa
Correction:
Sketch Regions are now only available in external sketches and this way of working is not available in internal sketches.
If available in internal sketches a lot of trimming  hasn't to be done anymore. This makes sketches more stable and working more productive: Hou van choose which cloosed loops inside the sketch has to be extruded without trimming all the sketched items.
Sketched loop areas may overlap: In that case simple click the areas which have to be extruded without having to create closed loops which do not overlap.
