Please find attached images & the model, to demonstrate dimensions display when the annotations
are activated.
Attached part is with mulitiple features& when we activate the annontation dimensions display, for some of the dimensions, the witness lines are not touching the object line.This is due to the sketcher dimensions
created for the first feauture.But the requirement is, when ever the new features are created with specific dimensions, proper display of dimensions to be made automatic & ther should not be any manual drafting work.
This will reduce the drafting time & will be very much useful, incase we want to automate the 2D drawing process.
