Add a slot in the sketcher or hole wizard. Slots take way to long to make.
Look at the Sketcher Palette when in sketcher. There are predefined shapes that you can use. One is called Racetrack that is a slot.
You can also make your own and add them to the palette.
Yes, and it will save your time and boost your design cycle time.
