In symbol placement , when placement offset is selected , it is not possible to use an existing 2D line (or intersection) to locate the offset point.
How to put a symbol in a drawings by "Offset" there leaning on existent entities?
example:
A symbol with a star placas at offset at a table, a symbol, or other entitas.
Then the investment must be accomplished with an intersection, one summit, etc.
It is possible to use the option "Offset " of a symbol in comparison with other one while positioning this one in comparison with entities
(example: intersection of two entities)
