When creating BOMs and other tables in drawings you should be able to snap that table (from edge or vertex) to the drawing format. Defining table position by absolute position is a cumbersome workaround which requires memorisation of the measurements of the particular drawing format being used.
This will make drawings, cleaner, more presentable and easier to execute.
