The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Ability to specify curve for draft hinge
You can select a curve for a draft hinge, have been able to since I started using Pro/E 17 years ago.
The curve must lie on the surfaces to be drafted and must completely cross the entire surface.
Perhaps you can post the specific problem that you are having with curve driven drafts and folks can help you through it.
