The symbol_spell check definition from the Creo 2 ModelCheck help says:
"Checks drawing symbol for spelling mistakes. If any are found, you can highlight them or highlight an correct them. Also, you can add the word to the dictionary so that ModelCHECK accepts it as correct."
Looking on PTC's site document CS191447 says:
PTC's own help files says nothing about it only working for variable text.
Even though this check should be considered a bug according to PTC's help files I would like the symbol_spell check to check ALL words in a symbol. It shouldn't matter if it's variable text or not.
