We're now using the "Creo Elements Pro 5.0".
Part of CAM, I want to diameter correction and,
to track processing to create a spiral curve Taper pipe threads.
But "Creo Parametric2.0",
because it can not be performed processing you want because there is no ability to diameter compensation
I want you to add "function to diameter compensation and, in orbit processing have created a spiral curve".
