The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Splitting surface by curve
Hi.
I would like to suggest new function "Split Surface by Curve".
This function exists in Creo Simulate - "Surface Region".
I need same functionality in Creo Parametric.
Note:
There is also automatic splitting in Moldesign.
Regards
Martin Stary
4 Comments
MartinHanak
24-Ruby II
Just a comment...
Currently it is possible to display yellow cross-hatching inside area surrounded by sketched curve.
MH
mwodarz_INNEO
and it is also possible to split quilts with curves
and if you want to solidify the quilts and want to keep the patches, then you can convert one patch with the warp feature
but in your example I would use a cosmetic sketch with a cross hatch or a ECAD region with a tiny height
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
