Spot Weld feature to be made more user friendly
Hi, This is reagarding spot weld feature option in Proe. We find it a bit difficult to use. First we are required to create 3d points and then use spot weld feature. This becomes difficult if the dimension between any two points (spots) needs to be edited. Our requirement is that the points should be generated in the weld feature itself and all the dimensions should be highlighted to make it easily editable. Pl feel free to contact me (Faizan) on 8698030545 in case of any doubt.
1 Comment
Community Manager
Status changed to: Archived
