We should be able to create a spot weld on a surface explicietly, reference to a curve ,edge, surface, planes, axis, points.
Spot should also be created by following a curve and able to pattern it as well.
A report should be generated of the spots distances (X,Y,Z) from the respective reference and should be editable.
distance between two spots should be given and should also be edited.
