In Creo 3 M170 the config.pro Option "mfg_misc_user_options" was implemented.
With this Option it´s possible, to Change some Standard values with help of the file "ncmenueoptions.xml" placed in Common Files\text\templates\mach_sim\.
Please add here also lines for the "save a CL file" menu.
I referee to call 14187158
