I've been asked to raise this enhancement request on behalf of a couple of colleagues.
Their main issue was:
"When trying to drag a component for reorder in the model tree, the holding time is too short to reorder well, the component will get restructured into another sub-assembly"
And the response we got from TS was:
"The issue is considered as works to spec since the holding time was implemented per PD's decision."
The users are finding that when they try to drag a component in the model tree to reorder, Creo is restructuring the component into a sub assembly.
Once this happpens, the ability to undo is lost and it is a pain to back out of.
Components are snapping way too quickly into a restructure.
We would like to see either:
1. Slow down the process (back to 2 sec as it originally was) so the the user has time to see that a restructure is going to occur instead of a reorder.
2. Have the ability to toggle and choose b/w restructure and reorder if the system defaults to a restructure.
3. A config setting to allow the user to set the default time to a longer value.
