Stop also copying relations when using the copy paste function
When you have a relation in a part or assembly and use the copy paste functionality to copy-paste a part or assembly to another assembly, the relations are also copied. This leads to unwanted relations in the relations file.
See also article CS282060
https://www.ptc.com/en/support/article/CS282060?&language=en&posno=1&q=CS282060&source=search
2 Comments
MasterDrew
7-Bedrock
Ideally this could be controlled by a configuration option. In my experience 80% of the time I don't want to paste the relations, but sometimes it can be very handy.
One hacky work around I do now is to always add a line at the end of my relations for all parts and assemblies:
/*End of Relations
And if I see any code after that line then I know it was copy-pasted in. That way it's really fast and easy to delete if I don't want to keep it.
RobertH
That extra line in the relation is also in our startpart template for exactly the same reason.
Controlling it by a config option is a solution but when you need it to be copied, I don't think you are gonna change the configuration for that.So you turn the automatic copying off and when you need it you just copy paste the relation.
