When you have a relation in a part or assembly and use the copy paste functionality to copy-paste a part or assembly to another assembly, the relations are also copied. This leads to unwanted relations in the relations file.
See also article CS282060
https://www.ptc.com/en/support/article/CS282060?&language=en&posno=1&q=CS282060&source=search
