Stretch Workplane Border
Sometimes when creating construction lines on a workplane, there is an intersection between construction lines which lies outside of the workplane border. Currently I work around that by creating one or more additional construction lines outside of the border so the border is stretched so the intersection I want is visible. Here's an example where there is an intersection that is outside of the workplane border. What I would like is the ability to stretch the border so that the intersection is visible.
3 Comments
KristofTheeten
6-Contributor
Peter,
you can do this by changing the size of the workplane.
Right-click the workplane and change the Min Size.
Or would you just prefer another way?
Kristof
PeterKehoe
The problem with "Change Min Size" is that it would be difficult to know what values enter to get the border the correct size. I want the ability to drag one side of the workplane border dynamically to get it the correct size.
PTCModerator
Emeritus
Status changed to: Archived
