Support For .IFC Export (Industry Foundation Classes)
This request is for including .IFC export functionality for Creo Parametric.These are the files that are used for import into Tekla and other products.
7 Comments
ptc-3236555
1-Newbie
Is .IFC format added to Creo??
AndyHermanson
This would be great for us as well for use with Programs like Revit.
slapha
IFC is the standard AISC is moving towards.
"AISC has been at the forefront of advancing interoperability through open standards since adopting the CIMSteel Integration Standard (CIS/2) in 1998 as an open standard for the structural steel industry. Since then, however, the landscape of software interoperability and integration has changed dramatically and even after a decade of progress, the issue is not solved. In addition, CIS/2’s “steel-only” format has meant that other solutions were needed as other disciplines began demanding data exchange.
These cumulative changes have led to AISC’s new strategy to advance interoperability across the construction industry: assess and enhance data exchanges available today and integrate that knowledge into IFC, a common data schema that makes it possible to hold and exchange data between different proprietary software applications. Although IFC has yet to address some details of a building’s life cycle, and does not yet cover the depth of data that CIS/2 encompasses, the IFC schema aspires to cover every aspect of design, procurement, manufacture and assembly, and operations and maintenance. "
- http://aisc.org/newsdetail.aspx?id=29658
kaerts
I am going to (week 7-2016) test new software (non PTC) to export from Creo Parametric 3.0 with Windchill to IFC (ifc2X3) format for Aconex BIM.
It will look @ the simplified rep & a filter for which parameters/rep to export.
The software developer will offer this software to PTC, as a basic export format in Creo Parametric 3 & 4.
For large project you have to do/have BIM by law in Europe!
So if PTC is smart.....
First prtscn of the test in Creo 3.0 M080 with Windchill.
PTCModerator
Emeritus
HamsterNL
18-Opal
Here's another +1 for IFC
RobertH
