For hatching breaks, the dimensions with marking for a basic or inspection dimension are currently not correctly supported.
The break does not include the frame around the dimensions. The hatching is only hidden in the range of the dimension number and the tolerance. The identification of the frames is made considerably more difficult.
For basic dimensions this can be improved by increasing the size of the margin. In the case of inspection dimensions, however, this change leads to unsightly representations.
The figure shows the behavior for the different dimensions. The dimensions to the left of the respective hole have the normal margin width. On the right an enlarged margin is used.
Friends of fine, easily readable drawings certainly agree with this suggestion.
