NX allows the use to attach cutting plane symbols to a section view, with various options like arrow direction, text orientation, etc. This helps the user and any reviewers to correlate PMI MetaData in PDM to the 3D geometry rendering, for downstream business process workflows. The attached example shows a cutting plane symbol attached to an offset section view. Please add Creo support for the equivalent capability.
