“Suppress” option needs to be added in the regeneration failures window (Suppress option in addition to the Suspend option)
- With Creo Elements/Pro 5.0, PTC introduced a new type of Reference -> “Topology System References”. -> A hole intersecting another hole will be referenced as a « System » Reference Type.
In case of failure, the Topology System Referenced children fail also ! This with the default option: regen_failure_handling no_resolve_mode
In failure window, suspending a failed child will also fail topological “System” children.
If the suppress command is restored in WildFire5 failure window, a failed child will not fail topological children.
