Surface Regions Improvements - Creo Simulate Option to Split into Segments
Please add the option when creating surface regions to have them spilt into separate segments.
In the part below one wants to put a constraint on one side and a load on the other side.  Currently you have to create 2 separate surface regions.
The first surface region goes all the way thru the part with no option to limit it to just one side of the part.
This would reduce the number of surface regions that need to be made.
Don Anderson
1 Comment
olivierlp
Community Manager
Status changed to: Archived
