Sustainability of the size of adjusted datum plane to an edge even after removing the original edge with cut or solidify.
After removing solid, it would be nice to keep the size of a Daum plane adjusted to an edge.
Warning message: Reference of datum outline (id 27333) is no longer in geometry; using default.
