Swapping two rows in family table
Allow the end user to swap two rows in the family table similar to being able to swap two columns.
Do this without using Excel because either the data transfer between the two is not reliable or that there is not access to Excel.
(Updated since they are going to be looking at ideas for the January 2014 TC Meetings)
5 Comments
LawrenceS
18-Opal
Yes, freely dragging both rows and columns to re-order them would be very usefull.  Especially not having any method to reorder rows is frustraiting.  If someone creates P/Ns out of order than they may get missed if the PN is not where it should be.
slapha
General sorting and reorganization of instances would be very helpful. I also like the idea of drag and drop over "swap". Same goes for being able to drag columns around.
I also created the following to allow for some form of grouping other than comment rows to visually separate lists:
http://communities.ptc.com/ideas/4385
Marco_Tosin
20-Turquoise
The link provided by Steven is no more reachable.
Try this Family table instance grouping
PTCModerator
Emeritus
NY_6644269
I knew we still couldn't freely drag and drop rows and columns in Creo Parametric 8.0, but it is very inconvenient for us? Would you please enhance this point in the latest version?
