With reference to the following PTC call;
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS161935
It would be a good idea to provide a system parameter of the tolerance class used in a model. This would allow the tolerance class to be displayed in a note or designated to Windchill.
For those unfamiliar with this an ISO standard tolerance class (e.g. fine, medium, course or very course) can be applied to the model via File > Prepare > Model Properties > Features and Geometry > Tolerance.
