Security Alert Log4j Security Vulnerability. Click here to know more.
Systematically show the feature name of any feature when using any filter
It would be very useful to systematically show the feature names of any feature when using any filter.
Acually, the names of Quilt or Surface features are not shown when using Quilt or Geometry filters.
Show names of quilts, surfaces in selection fields -> Pick From List, UDF fields, ...
3 Comments
psobejko
Another example of this problem is that currently, the Pick from List does not show the name that the user has given to a feature, just the generic "type".  Why not show this name as that would make it so much easier to quickly zero-in on specific entities?
In this example A_2 axis is easy to select; However, when you have a lot of closely spaced items on the screen, identifying which axis to select from a list of "FXXX(PROTRUSION)" is not easy...  Wouldn't selecting an item called A_2(AXIS):F9("LARGER_DISC") be easier?
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
