Take account of the gap between teeth with gears-pair connections.
This would be sort of like allowing definition of a positional limit between the gear axis, in addition to the velocity constraints, right?
it's more complicated, because if we change the direction of rotation or if we change profile of our gear teeth it's not the same.
Be able to have the real contacts could be the best.
PS : sorry for my late answer
