Chamfers: when you measure a O X O and / or a O1 X O2 chamfer, the result dosen't correspond to the shown dimension.
The default "Offset Surfaces" type of value is not useful for construction.
Please add a config.pro option to choose "Tangent Distance" by default.
PTC suggests defining a mapkey to not use the default “Offset Surfaces”: article CS53776
« Advanced Chamfer Topics » explains how these chamfers are defined.
