We're using Tapes as Spot Tapes with different charater, controlled by Tape Spools.
For instance SPOT_ Tape_white or Marker Tape etc..
But PTC Creo does not give us the ability to use that method, because TOOLKIT API do not support this.
If we want export the Tapes there is no chance to match the reflected Tape Spools.
Means we have only the Name of the Cosmetic Tapes to identify, but not which KIND of Tape is it. So for us useless !
Please implent to the Creo4 Parametric Cabling Toolkit API the function to get also further Tape Feature Parameter.
- GET() User defined Parameter
- GET()TAPE_SPOOL Parameter
Example
