Task Based Application Libraries in Toolkit
"Applications created using different Creo Parametric API products are interoperable." - great idea. But hard to use:
GetProToolkitDll (string ApplicationId)
ApplicationId
The DLL's identifier string, acquired from either:
  • A call to ProToolkitDllIdGet within the DLL application
In order to run the function from an external DLL, I need to get ID from DLL. But to do that I can only from code DLL. Then you need to transfer this ID from one application to another. Weird.
Need to use the name of the application from protk.dat - it is constant unique string.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
