Method to align text (of any font) so you can add numbers 1, 2, 3,.... followed by an aligned paragraph. Preferably a space that can be adjusted. Essentially a way to create what would be considered a standard engineering note on a drawing.
If standard text formatting is not possible in a Creo drawing (hard to believe),
Perhaps a table, or repeat region, that does not have visible box-outlines?
End.
