In Creo 3.0 and Creo 4.0, when using the Measure tool on the Analysis tab, the pop-up results dialog box remains a fixed font size, and there is no way to affect that font size. This presents a problem when creating screenshots for presentations; often the font is too small, and the user is forced to perform copy/paste/resize tricks in order to get it to look right. Or, a user may have poor eyesight and simply have trouble reading the smaller font.
Providing a config.pro option (e.g. "measure_results_font_size" with values "small"*, "medium", "large") that controls this would enable finer control and a streamlined process for presenting results in a screen-captured format.
