The ability to Show sketcher based Ordinate dimensions in 3D using Show Model Annotations
Currently it is not possible to show sketcher based ordinate dimension on 3D level using Show Model Annoations (it can only be shown in drawing level) - See example attached.
PTC is not planning to fix this as it is regarded as standard/intended functionality (PTC CS152204 / SPR 2856507/2203317)
This is also a frustrating limitation when trying to apply other annotations to the 3D model, for example a GTOL on an ordinate dimension.
You have to re-create the dimension (driving) and then only you can apply the GTOL on an ordinate dimension in 3D OR use linear dimensions, which are not always practical.
