1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Design systems / assemblies to address client challenges - from initial concept to delivering final product.
2. What version of Creo Parametric are you currently running?
8
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Drawing templates can only be used during the creation of a new drawing. It would be very useful to be able to apply a template to a sheet within an existing drawing. For multi-sheet drawings this would save a lot of work. On an existing blank sheet, the applied drawing template would use the currently active drawing model and place the views on the sheet. This would eliminate having to create a new drawing, and then importing it into an existing drawing.
4. What is the use case for your organization?
Adding details for additional assemblies and/or parts to an existing multi-sheet drawing, and updating legacy drawings, in a timely and efficient manor.
5. What business value would your suggestion represent for your organization?
Time saved in the revision and addition to existing drawings.
