Drawing templates can only be used during the creation of a new drawing. It would be very useful to be able to apply a template to a sheet within an existing drawing. For multi-sheet drawings this would save a lot of work. On an existing blank sheet, the applied drawing template would use the currently active drawing model and place the views on the sheet. This would eliminate having to create a new drawing, and then importing it into an existing drawing.
